Stationary Engines Discussion Forum
Onan Diesel?
D.Miller
01-24-2005 17:26:02
I am working on a Onan diesel 5kw generator model 6DJE,this old engine has very few hours on it but has not been run in 10 years,I cleaned the fuel tank changed all of the fuel filters and bled the system as the manual states. I have good fuel flow to the injection pump and there is a steady flow of return fuel to the tank but I do not get any fuel to the injectors,It has a electric fuel shut off that acts like a plunger against the fuel control lever it moves away when cranking but the fuel control lever will not move even if I try to help it.Any ideas?
Bob
01-24-2005 19:33:49
 Re: Onan Diesel? in reply to D.Miller, 01-24-2005 17:26:02
If I recall correctly, there is a common "rack" that connects the fuel injection plungers together, and to the governor. It sounds like a plunger(s) may be stuck in the "no fuel" position by rust, or dried-up fuel varnish, which causes the whole mechanism to be stuck in the "no fuel" position.
I have factory manuals for the engine, but probably can't find them, offhand, since they were packed up 2 moves ago!
