Stationary Engines Discussion Forum
AC Engine
old_oil
02-17-2005 04:22:49
Hi, I need help in trying to date an engine. It is coupled to a lincoln welder, and looks like it came out of the stone age. Runs good welds okay for its age. I can't see any kind of tag, or plate on it, but only a few numbers on the block. Where do i look for serial, or model numbers? Then a place to match them up for a year. thanks old_oil
old_oil
02-18-2005 13:52:33
 Re: AC Engine in reply to old_oil, 02-17-2005 04:22:49
I feel like a dork,
I found a tag up behind the mag that reads 121j the J could possibly be a D, it is pretty rusty.
The type on the mag reads FMJ. The welder it is coupled to looks to be of the same era, and I have the serial, and type numbers for it if there is a website to ID it. Thanks everyone
old_oil
J. Schwiebert
02-17-2005 15:08:52
What numbers are on the block?
old_oil
02-18-2005 09:14:43
 Re: AC Engine in reply to J. Schwiebert, 02-17-2005 15:08:52
The numbers are AM 1339 14 Of course it has been painted a few times but I can't see any tags, anywhere. thanks
Kent of SW MO
02-19-2005 10:20:09
 Re: AC Engine in reply to old_oil, 02-18-2005 09:14:43
That number you posted look like a John Deere casting number. Could you post a picture?
Kent
old_oil
02-19-2005 14:23:51
 Re: AC Engine in reply to Kent of SW MO, 02-19-2005 10:20:09
I miss read the number it is AM 4339-14 I wrote another reply because I found a tag on the block that reads 121d the d could possibly be a j it is pretty rusty. thanks alot kent
Kent of SW MO
02-17-2005 08:08:10
Is your engine a 2 cyl. vertical? If so it may be a THD Wisconsin.
Kent
old_oil
02-18-2005 09:16:23
 Re: AC Engine in reply to Kent of SW MO, 02-17-2005 08:08:10
It is a 4 cylinder with a Wico mag.
