Stationary Engines Discussion Forum
Le Roi engine parts
AndrewD
02-23-2005 16:55:28
does anyone know where i can get engine parts for a le roi d176 and a d201? i want to restore these engines, but dont want to start untill i know i can get the parts to fix them. thanks
hector gemme
02-24-2005 10:07:42
 Re: Le Roi engine parts in reply to AndrewD, 02-23-2005 16:55:28
HI What parts you need and this motor is he a 4 cylindre gas. hector
AndrewD
02-24-2005 16:15:01
 Re: Le Roi engine parts in reply to hector gemme, 02-24-2005 10:07:42
i need at least the full gasket set, rings, rod and main bearings, and might need some valves. both of these motors are 4 cyl gas. thanks
J. Schwiebert
02-24-2005 17:34:02
 Re: Le Roi engine parts in reply to AndrewD, 02-24-2005 16:15:01
How do I contact you?
R
06-01-2005 18:38:40
 Re: Le Roi engine parts in reply to J. Schwiebert, 02-24-2005 17:34:02
DO YOU HAVE PARTS FOR A M3 LEROI S-3816 OR A PICTURE R
hector gemme
02-25-2005 04:45:42
HI The motor ROI has 1 v8 and 4 cylindre now I dont have the you need check CLEVITE PARTS I have a friend he has 1 motor complete but 15 years not start. HECTOR
AndrewD
02-24-2005 17:37:26
johndeere430c@yahoo.com
J. Schwiebert
02-23-2005 18:07:26
What parts are you looking for? When I worked for Dana we had parts for them in the catalog. Don't forget to look in the A-C section as well especially for the 201.
AndrewD
02-23-2005 18:23:58
 Re: Le Roi engine parts in reply to J. Schwiebert, 02-23-2005 18:07:26
i am going to need just about everything to do a motor job-rings, bearings, gaskests,etc. both engines have been stuck for some time-i am going to guess the 201 has been stuck for at least 25 years. thanks for the help
Fluhart
06-14-2005 11:49:41
 Re: Le Roi engine parts in reply to AndrewD, 02-23-2005 18:23:58
Hello,
I've got a couple of Le Roi power units on ebay. To view, go to ebay and type the item number (7523669372) in the search box.
M. Nix
04-25-2005 07:10:27
Hi, I have some new Le Roi valves I picked up with some other "stuff" at an auction. I don't know what they fit but I can check their dimensions if your interested.
M. Nix
