Stationary Engines Discussion Forum
Wisconsin Model #'s
Jerlee
03-05-2005 19:00:01
I just purchased an old two cylinder Wisconsin and the Spec. tag that was on the engine cover is missing. Does anyone know if the Make and/or Model # is stamped anywhere else on the engine block ? Or if there is anyway of finding out this information ?
Jerry
ira
03-13-2005 19:05:28
 Re: Wisconsin Model #'s in reply to Jerlee, 03-05-2005 19:00:01
could also be a model tf
ira
03-11-2005 20:00:51
your 2 cyl. could also be a model te I have a model te I bought from a junk yard at 20 cents a pound . cost me 48 dollars. parts are available but pricey.you might call this person in minn, roger stadler , 651-292-1556. the te has 12hp at 2400 rpm . mine has a rockford clutch on it. good luck .
jerlee
03-11-2005 23:48:04
 Re: Wisconsin Model #'s in reply to ira, 03-11-2005 20:00:51
Hey Ira, what would ya take for the rockford clutch ?
Jerry
ira
03-12-2005 15:07:39
 Re: Wisconsin Model #'s in reply to jerlee, 03-11-2005 23:48:04
make me an offer I cant refuse. I live in northwest In. I would rather sell it as a whole unit.
Steve-Maine
03-06-2005 03:12:04
Try to find casting number of block and I should be able to tell tou the model.This would be on the side of the base of engine
jerlee
03-06-2005 09:23:14
 Re: Wisconsin Model #'s in reply to Steve-Maine, 03-06-2005 03:12:04
Hey Steve-Maine, thanks for your help on this matter. I finally found some numbers on the side of the block behind the magneto. (BA-51-A) and just above that is the number (84-D) or at least it appears to be the letter "D". Could possibly be (84-O). Any information you could give me on this would be of great appreciation. I am going to need new rings, rod bearings, gasket set, one intake valve-spring, one exhaust valve spring with the retainers and keepers. Also if you have any advice on where to purchase these parts at a resonable price, I would appreciate that as well.
Steve-Maine
03-06-2005 11:14:38
 Re: Wisconsin Model #'s in reply to jerlee, 03-06-2005 09:23:14
This is either a TH or THD Wisc. I buy parts from www.northeastmachine.com They have real ggod prices, good service. Good Luck
Steve
jerlee
03-06-2005 17:09:18
 Re: Wisconsin Model #'s in reply to Steve-Maine, 03-06-2005 11:14:38
Yo Steve-Maine, I hate to keep bothering you about this but does the info I give you indicate the year of the engine ? I thought maybe the 51 meant 1951.
Jerry
Steve-Maine
03-07-2005 04:06:25
 Re: Wisconsin Model #'s in reply to jerlee, 03-06-2005 17:09:18
The 51 is part of casting number of block. There might be other numbers that tell year built. Northeast Machine could tell you that.
