Stationary Engines Discussion Forum
1cyl Or 2cyl Diesel
T_Bone
03-07-2005 09:37:39
Hi All,
I'm wanting a small, 10hp to 15hp @ 3600rpm or 7hp @ 1800rpm, 1cyl or 2 cyl diesel engine to run some home projects. Diesel is a must have requirment.
From what I've seen of the older engines there all built extremely heavy, correct? If not, what do I need to look for, brand/model?
I wouldn't mind something that weighed 200lbs or less nor does it have to be old. A slower (1800rpm or less) rpm engine would be nice. What brand/model do I need to look for?
Suggestions?
T_Bone
Bob Cousins
03-11-2005 16:10:28
 Re: 1cyl Or 2cyl Diesel in reply to T_Bone, 03-07-2005 09:37:39
There are a bunch of diesel options here.
For slow speeds, clones of the old Lister engines are available from lots of places. Suggest you check out the following links:
Link
A another vendor is mdmo@rfci.net (Mike Montieth).
Some of these importers also have higher speed
engines.
T_Bone
03-12-2005 00:39:36
 Re: 1cyl Or 2cyl Diesel in reply to Bob Cousins, 03-11-2005 16:10:28
Hi Bob,
Thanks for reminding about listiod.com. I had forgoten all about that website. I ran into it a couple years back. I see George has added a new engine line, 12hp/2cyl petter engine but doesn't list a price, to new.
I wasn't looking for a high rpm diesel but was looking at some of the newer air cooled 10hp and it seams they all use 3600rpm. Most are on 2-pole generators so that makes since on the high rpm, just not cost effective.
T_Bone
