Stationary Engines Discussion Forum
Hercules ZXB Static Timing Help
Larry White
03-08-2005 04:56:42
I failed to mark the timing gears on my Hercules ZXB engine before I removed the camshaft and need instruction on how to put it back in time. I can see no marks on the gears.
Thanks,
Larry
Bob
03-08-2005 05:58:15
 Re: Hercules ZXB Static Timing Help in reply to Larry White, 03-08-2005 04:56:42
Here's some ideas, if you can't find the marks, from the "N" board:
Larry White
03-08-2005 10:22:32
 Re: Hercules ZXB Static Timing Help in reply to Bob, 03-08-2005 05:58:15
Thanks! That is exactly what I needed to know.
Larry
Larry from MD
03-08-2005 16:54:57
 Re: Hercules ZXB Static Timing Help in reply to Larry White, 03-08-2005 10:22:32
There are punched dots on the gears that you line up.On the crank gear the punch mark is in line with the key.
Denny Ryan
01-06-2007 06:02:37
 Re: Hercules ZXB Static Timing Help in reply to Larry from MD, 03-08-2005 16:54:57
If the valves or in time with the crank you will need to find additional timing marks for the timing of ignition! On my zxa the flywheel has, SPK and TDC stamped in the flywheel in 2 locations, 1 is located on the front side of the flywheel and must be viewed through a hole in the rear engine support, the second one is stamped into the outter rim of the flywheel and I have no reference for it, I have no bellhouseing.
