Stationary Engines Discussion Forum
Wico Magneto's
jerlee
03-11-2005 23:52:33
I'm trying to trouble shoot my magneto. Points are good, and l've even tried a new condenser still no fire. Does anyone know how to test the coil ? I can get about an 0.5 volt reading through the points is all but absolutely nothing at the spark plug wire connections. Any help would be great. Thanks; Jerry
ira
03-13-2005 19:01:40
 Re: Wico Magneto's in reply to jerlee, 03-11-2005 23:52:33
not likly the coil . try filing the points with some sand paper make sure the gap is right .if this is your two cyl. wisconsin they should be set at .015
Kent of SW MO
03-12-2005 15:25:36
Are you tring to read the resistance of the high tention side of the coil directly on the coil. If so you should have a reading in the 7000 (7K) to 10000 (10K) ohm range. If you are tring to read through the distributor bug you will read an open.
Kent
