Stationary Engines Discussion Forum
Briggs Stratton making a Knocking Noise Rod
Brad in SW MO
03-13-2005 18:58:52
I have a Briggs 11 hp motor that stars and runs fine but makes a loud knocking noise. I pulled the bottom cover off but can"t find any slack in the rod at all. Is there anything else that could cause the noise? Any help is greatly appreciated. Thanks.
lucasss
03-16-2005 17:09:45
 Re: Briggs Stratton making a Knocking Noise Rod in reply to Brad in SW MO, 03-13-2005 18:58:52
were the bolts that hold the engine to the tractor loose? if so, that can cause a knock. lucas
Bob
03-13-2005 19:23:25
If the rod is, in fact, OK, I have seen engines with a chunk of carbon or other foreign material imbedded in the top of the piston, including an errant throttle plate screw.
Way too much valve tappet clearance, or a worn bore or damaged piston can cause noise, too!
