Stationary Engines Discussion Forum
Help with Stover CT-3/Wico EK
Roland Warringt
03-21-2005 09:01:50
I am helping a friend with a CT-3. The WICO EK mag will show a nice blue spark at the plug when the rocker arm is tripped with a screwdriver. I place the end of a long screwdriver on the cyl head, bring it behind the rocker arm of the mag and use it as a lever to trip the mag. The spark is fine. If I turn the flywheel and let the trip finger on the push rod trip the mag I get no spark. I can't understand what the difference is. Could there be an issue with grounding or not grounding something with the screwdriver? Any ideas? Any help would be greatly appreciated. Thanks. Roland
notify
06-12-2005 19:37:30
 Re: Help with Stover CT-3/Wico EK in reply to Roland Warrington, 03-21-2005 09:01:50
Roland,...I was wondering if you solved the problem with your CT-3...I had a problem once like that with my CT-2....If you still need some help e-mail me at ..classicflyer@yahoo.com....Bill
