Stationary Engines Discussion Forum
CC oil for Wisonsin TJD?
Rob
03-30-2005 05:15:55
What should I put in the crankcase this spring?
Are these Autolite 386 the right plugs for this engine? I got it starting and running nice but there isn"t much spark out these plugs.
Kent of SW MO
03-30-2005 06:59:02
 Re: CC oil for Wisonsin TJD? in reply to Rob, 03-30-2005 05:15:55
I use a 30W HD oil on the THD I have on a Lincoln 180 welder. As fall as plug I use Champions D-16, if a mag like mine I use a UD-16. The "U" is a sparkgap in the porcilin(sp?) If the plugs are new check the mag. as a source of weak spark.
Kent
Rob
03-30-2005 07:11:13
 Re: CC oil for Wisonsin TJD? in reply to Kent of SW MO, 03-30-2005 06:59:02
I tried a Champion D-16 in there and it was a lot bigger spark. Much, much bigger spark.
Considering that, I figure the mag and plug wires are fine but it left me wondering if I could or should use that D-16 or another plug.
What"s the difference "tween that THD and TJD?
Thanks for the oil info.
Kent of SW MO
03-30-2005 12:21:16
 Re: CC oil for Wisonsin TJD? in reply to Rob, 03-30-2005 07:11:13
All the 2 cylinder Wisconsin except the TJD the piston come to TOP DEAD CENTER at the same time. A TJD"s alternates coming to TDC.
Kent
