Stationary Engines Discussion Forum
wico mag
Jeff Allen
03-30-2005 18:46:26
I have small Witte engine with a Wico mag.I can't get any spark at all.I took the cover off and sanded the points.Still no luck. One of the coils has alot corrosion on the out side of it.Could this be my problem?Thanks to any who apply.
Kent of SW MO
03-31-2005 06:17:37
 Re: wico mag in reply to Jeff Allen, 03-30-2005 18:46:26
Take a ohm meter and measure the primary and secondary of the coil. The primary should read low around 3 or 4 ohms. The secondary should read 7000(7K) to 10000(10K) ohms. Also check the condenser.
Kent
ronnie269
12-03-2005 19:06:12
 Re: wico mag in reply to Kent of SW MO, 03-31-2005 06:17:37
replace the condensor, about $6.00
