1921 2HP IH. POWER CONCERN
Mark
07-13-1999 17:38:38
Recently bought an old pendulum type shingle mill.While cleaning out an old building to set it up in found this old 2HP beauty.Does this have what it takes to run my mill?
Titan
07-13-1999 19:49:38
 Re: 1921 2HP IH. POWER CONCERN in reply to Mark, 07-13-1999 17:38:38
Don't know about that, but I'd sure like to know more about the engine.
Mark Zwicker
07-15-1999 18:22:50
 Re: Re: 1921 2HP IH. POWER CONCERN in reply to Titan, 07-13-1999 19:49:38
Just found out today through a serial# search that my engine is a 1921 kerosene skidded 3HP I-H #b42270.I'm having trouble getting it running.Instead of buying a 6volt battery i've hooked up a 6volt battery charger to the coil.Is this giving me enough spark for my igniter? Any other tips you might know to help me get a kick out of this old beauty would be helpful.I know nothing of these engines but i'm really enjoying working on this one.I'm assuming I can use gas instead of kerosene? The carb has 3 needle adjustments labled KER WAT & GAS? Everything else on the engine seems loose and I believe the original color to be green.Any info such as value, manuals,etc. would be appreaciated. Thanks Mark Zwicker
