Stationary Engines Discussion Forum
Wisconsin VH4D Flywheel Removal
Colorado Curt
04-15-2005 07:34:47
How do you pull the flywheel off of a VH4D Wisconsin engine? I have the nut off, but there are no points to pull from. Some of the Wisconsin flywheels have threaded holes to attach a puller, but not this one. I am hoping that some one out there knows a trick or two.
tadpole
06-02-2006 19:21:23
 Re: Wisconsin VH4D Flywheel Removal in reply to Colorado Curt, 04-15-2005 07:34:47
remove starter and take a pry bar put a little tension on flywheel and put blok off woodand hit the of crank shaft very solid it will pop off
george md
04-15-2005 09:38:43
Curt,
Book shows a brass mallet to hit the crank.
It's on a taper , I usually use two pry bars to
take up the end play and swat it a couple of
licks on the end and whala it jumps off.
george
genecot
05-08-2005 14:29:35
 Re: Wisconsin VH4D Flywheel Removal in reply to george md, 04-15-2005 09:38:43
George, or any one else. I have a problem with a vh4d engine on a trencher. It backfired and now will not start. Any idea on what the problem might be?
Colorado Curt
04-15-2005 10:16:55
Thanks George. We will give that a try.
