Stationary Engines Discussion Forum
MAYTAG
Jeff ALLEN
04-29-2005 14:00:56
I HAVE TWIN CYL. MAYTAG AND I WAS WONDERING IF IT IS A TWO CYCLE ENGINE.ALSO THERE IS A PIPE PLUG IN THE TOP OF THE CRANKCASE.DOES ANY OIL NEED TO GO IN THERE?ALSO HOW DO YOU START IT?THANKS TO ALL WHO APPLY.
n9lhm
05-01-2005 05:32:23
 Re: MAYTAG in reply to Jeff ALLEN, 04-29-2005 14:00:56
Yes, it is a two cycle. The knob on top of the angled pipe is the combination throttle/choke, it controls the air supply into the "carburetor". Turn the knob all the way clockwise at first, that shuts off the air and "chokes" it. After a few kicks with the starter, open the knob up 1/4 turn or so and continue to kick the starter until it starts. AFter it is running, fine tune the knob for an RPM and power peak. To shut it off, you open the knob counter-clockwise several turns until the mixture is so lean it won"t run any more. Good luck, post back if you have any more questions. Brian
Jeff ALLEN
05-01-2005 18:01:00
 Re: MAYTAG in reply to n9lhm, 05-01-2005 05:32:23
Brian,thanks for the reply.What is the oil to gas ratio?Thanks again.
n9lhm
05-01-2005 18:36:51
 Re: MAYTAG in reply to Jeff ALLEN, 05-01-2005 18:01:00
I generally use the little cans of Lawn-Boy oil, that mix up with two gallons of gas, not sure if that is 32:1 or 48:1, I doubt if it"s real critical. Most of the old engines run a little heavier on oil than the newer ones.
Jeff Allen
05-02-2005 19:57:52
 Re: MAYTAG in reply to n9lhm, 05-01-2005 18:36:51
Brian,I got it started late this afternoon.It ran pretty rough at first but finally smoothed out and ran fairly well.Thanks again for the help.
n9lhm
05-03-2005 11:06:27
 Re: MAYTAG in reply to Jeff Allen, 05-02-2005 19:57:52
My dad grew up on a farm where they had one of these, he used to tell a lot of good stories. One was that in the winter time they would run the washing machine and engine inside, and stick the exhaust hose in a five gallon bucket of water. The carbon monoxide and dioxide dissolves in the water, supposedly. I've tried it and it works pretty well (at least it kills the smell), but since it is a two cycle engine, the water gets oily quick. (Disclaimer: I'm not recommending you try this!) He also had a friend whose dad mounted their 2 cylinder maytag engine on a bicycle after they got high-line power and didn't need the gas engine anymore. Said the bike would go pretty fast with him on it. It would be interesting to try. Brian
