Stationary Engines Discussion Forum
Wisconsin TJD governor problems
benjy
05-06-2005 05:00:35
I have a Wisconsin TJD, that after being rebuilt, has chewed up two governor gears. The first failure was catastrophic with gear disintegration and breakage of shaft, the second time, the outside 1/8-1/4" edge of gear had all teeth ground off. Distributor drive gear, cam gear, crank gear and other governor parts look ok. Cam thrust pin, spring, and button are in place. Engine is not always operated at governed speed, set for 2500 RPM, engine is operated routinely at 1800 RPM, spring is on governor lever hole number five. Appreciate any insight or suggestions as to what is causing this problem. Thanks, Benjy
