Stationary Engines Discussion Forum
wisconsin v4 engines
havvey
05-08-2005 10:30:54
i have a vp4 on a pump what is the difference from vg4? anyone got parts for these mags etc?
Jim in rush co.
05-23-2005 06:56:37
 Re: wisconsin v4 engines in reply to havvey, 05-08-2005 10:30:54
I have same as new Wico mag. has less than 50hrs
on it, replaced engine right after bought mag new.
was built by Standard, who has all of Wico and Fairbanks Morse dies parts ect. you can email me at jcloud@cnz.com
JOB
05-23-2005 04:03:53
The VP4 has not been made since 1954 or so I was told by a Wisconsin distributor The VP4 is rated at 23.5 horse at 1400 26.8 horse at 1600
29.0 horse at 1800
30.2 horse at 2000
31.0 horse at 2200 The manual says the mag from a VG4 will not work on a VP4. I did switch mags once, got it to run on a couple of cylinders then moved plug wires around till it ran smooth. The fireing order is the same. The VG4 has a different cam in it I believe. The VG4 is rated at 25 Horse at 1400 RPM 29 Horse at 1600 RPM 32 Horse at 1800 RPM 34 Horse at 2000 RPM 36 Horse at 2200 RPM 37 Horse at 2400 RPM
Wisconsin would have had to make some internal changes to the VG4 engine to get more HP out of it. The newer engine have inserts on the rod bearings. Back in 1965 the VG4 still had poured rods.
Scott PA
05-08-2005 18:15:14
The VP4 is more HP than the VG4, a New Holland dealer should be able to get mag parts because these engines were used on NH forage harvesters and similar engines on NH balers, there are numbers on the side of the mag, one side has more numbers stamped than the other side, it could have a Wico or Fairbanks Morse brand, let me know if you can't find anything.
Thanseel
05-25-2005 00:35:18
 Re: wisconsin v4 engines in reply to Scott PA, 05-08-2005 18:15:14
Kind Attn: Sales Department
Dear Sir,
Kindly quote your best price for our following requirement:
Our Ref: No. 1763
Item Description Unit Qty
PARTS FOR "WISCONSIN" ENGINES, AIR COOLED, 2 CYL. MODEL: TH, THD, TJD NON INTERCHANGEABLE PARTS
1 Oil Pump Assy. P/n. KAA-102 Nos 2
2 Oil Pump Body Assy. P/n. KA-63D-SI Nos 2
3 Engine Gasket Set P/n. Q-41 Nos 4
4 Gaslet P/n. QD-846 Nos 2
5 Carburetor P/n. L-63BL-SI Nos 4
INTERCHANGABLE PARTS
6 Valve Stem Guide P/n. AD-41 Nos 6
7 Valve P/n. AE-75-B Nos 6
8 Valve P/n. AE-75-D Nos 6
9 Valve P/n. AF-49-A Nos 6
10 Valve Spring P/n. AF-54 Nos 6
11 Seat P/n. AG-26 Nos 6
12 Valve Rotator P/n. AG-31 Nos 4
13 O-Ring Oil Seal P/n. JK-50 Nos 8
14 Fuel Pump P/n. LP-62A-SI Nos 4
15 Spark Plug, Champion No. D-16-J P/n. YD-6-SI Nos 2
Please include the following details in your quote, where applicable: 1. Price and Currency (FOB C&F Dubai, UAE):
2. Manufacturer and Country of Origin:
3. Weight and Volume:
4. Delivery:
5. Certificates (Material Conformity/Test Certificates, etc.):
6. Packing (suitable for Sea/Air transportation):
7. HS Code (Brussels Tarif Code):
8. Technical Data Sheets/Drawings/Details/Description Leaflets, etc:
9. Payment terms and condition: 10. If any other extra details available?
Kind regards,
Thanseel H.
Manager
