Stationary Engines Discussion Forum
John Deere 1 1/2 HP model E
Ronald Campbell
05-12-2005 20:01:55
My engine will not run. The magneto has tested good. When the timing marks are aligned (cam gear and crank gear), and the other timing mark on the cam gear is up, the piston is on the exhaust stroke. Should the piston not be on the compression stroke?
WayneO
05-12-2005 23:21:35
 Re: John Deere 1 1/2 HP model E in reply to Ronald Campbell, 05-12-2005 20:01:55
When you turn the flywheel slowly, the ingnitor trip should snap the ignitor when the "spark" mark on the flywheel is in line with the pushrod, and this will be at the top of the compression stroke. Also check the gap you have in your ignitor points. If everything is set correct the JD E engine is super easy to start.
