Stationary Engines Discussion Forum
LE ROI Powerplant Generator 1943
Donald Kitchell
05-31-2005 15:01:08
Where can I find a manual for a little toy that I have acquired. It is a 1943 LE ROI Power plant setup. It is a motor and generator complete setup. It has all the markings on it from the US Navy Signal Corps. It is rather massive in size and rated at 209 amps when the "Log Stroke" motor is turning at 900 rpm. It is so old that it only makes 120 volts. The interesting thing is that it runs, generates power and is multi-fueled. Natural gas, propane or gasoline. I would appreciate any info and directions that you folks could point out. Thanks. Donald Kitchell
Brian Mann
12-12-2005 12:44:19
 Re: LE ROI Powerplant Generator 1943 in reply to Donald Kitchell, 05-31-2005 15:01:08
I have what sounds the same as yours. Mine is a LeRoi 4 cylinder 4.5x5 gas engine. It has a 25kw Westinghouse generator connected and is all together a neat package. It is dated 1942 and is blue. Have you ever found any literature on yours ? If so I would be glad to pay for a copy if it's the same engine as mine. What is the mod number on your tag ?
Thanks
midpw
06-12-2005 05:58:20
Post this request over on Harry's site. The guys there are kind of amazing.
