Stationary Engines Discussion Forum
Point/Condenser Gap
BriggsHelp
06-08-2005 05:12:02
Had no spark on B&S engine on my Troy Built Tiller. Replaced points, condenser, and spark plug.
Now I have spark to plug. However, I don't know what the appropriate "gap" should be between conderser and point. Can anyone provide that????
Thanks
Bob
06-08-2005 07:58:52
 Re: Point/Condenser Gap in reply to BriggsHelp, 06-08-2005 05:12:02
Most, if not ALL Briggs points are gapped at .020".
BriggsHelp
06-09-2005 06:31:56
 Re: Point/Condenser Gap in reply to Bob, 06-08-2005 07:58:52
Bob;
Thanks for the reply. Set gap at 0.020" and ran GREAT.
Now I bump into problem #2. Engine ran GREAT after re-gapping etc. However, keyway sheared and now the keyway groove is severly distorted. Not sure why this happened.
Now, I'm at a loss of how to fix the distorted keyway groove. Any suggestions????? ??
Thanks
Bob
06-10-2005 08:44:20
 Re: Point/Condenser Gap in reply to BriggsHelp, 06-09-2005 06:31:56
Replace the key, and tighten the flywheel TIGHT. You could even put a little locktite on it.
(I would not recommend the locktite on a MOWER engine, because if the blade hits an obstacle, the key needs to shear, but on the tiller engine, I would think you'd be OK.)
Mower engines use a SOFT key so it shears easily, but on the tiller engine, you could use a steel key, if you can find one that matches up, which would be better with the worn keyway.
