Stationary Engines Discussion Forum
IHC LB stationary engine
Sawyer S
08-01-2005 16:28:19
Would someone please help me with this thing! The throttle shaft was broke when I got it, but I've fixed that. Now I don't know which way the spring on the throttle shaft inside the motor goes. Also which way the lever on the end of the shaft goes (up or down). Seems like the spring on the throttle shaft should be pulling the rod against the governor?
restogreen
08-16-2005 18:18:28
 Re: IHC LB stationary engine in reply to Sawyer S, 08-01-2005 16:28:19
The throttle plate on the carburetor will always be in the OPEN (Full Throttle position) when the engine is OFF!!!. Therefore , the spring will allow the throttle to always TEND to be open; THE GOVERNOR then reacts against the spring tension to CLOSE the throttle plate to CONTROL the GOVERNED SPEED.
You can get an operators manual from Hit-N-Miss Enterprises in Orwell ,Ohio. I have had 2 of these IH engines. The last LBA I purchased at a very good price because the engine "would not run!" . I removed the flywheel and coverplate to access what you are talking about. REMEMBER TO REPLACE THE SPRING STEEL FORK IF BROKEN AT ALL!!
I re- indexed the square shaft so the throttle plate was spring loaded open when engine OFF.
ENGINE RAN GREAT!
