Stationary Engines Discussion Forum
WATERLOO
DGK
08-09-2005 17:32:03
HI How do identify a waterloo engine? THANKS DOUG
Turk
08-14-2005 10:17:23
 Re: WATERLOO in reply to DGK, 08-09-2005 17:32:03
Any chance you can post a picture? Waterloos are cast in one piece, the larger ones, like 4hp and up? have a removable water hopper. The shape of the water hopper can vary wildly depending on whether it is a Waterloo Boy or a contract engine, like Sandow, John Smyth, Majestic, etc. The contract engines mainly used a governor with weights in the flywheel, and I think all but the earliest Boys had the governor mounted between the crank and the rear of the cylinder, similar to an Economy in position at least. Some did have a cast cover over the weights and timing gears, but very few of these covers remain. In my opinion, an early Waterloo IS the classic Midwest farm engine. Bill
Jeb2N
08-10-2005 10:01:41
The waterloo engines along with the other brands that were made by waterloo but sold under a different name were generally much longer than most of the other horizontal engines. Spoked flywheels, and the water hopper was squared off with (i beleive) a round hole in the center. I also beleive that the block was bolted to the crankcase rather than the two being cast as a single piece. Should have a cast iron cup to fit over the flyball governor just like the crank guard. I know it's general, but hope it helps.
Jeb
