Stationary Engines Discussion Forum
Ignition for Engine
TwinCreek
08-26-2005 04:39:46
I will soon be ready to try and start my first stationary engine , which is a Fairbanks Morse Model Z dish pan engine. I do not yet have an ignition system for it. I have seen where "buzz boxes" etc have been used for these engines. I am a newbe to these engines and my question is can I use a 12 volt car coil, 12 volt battery, and a condensor to rig up an ignition for this engine? Eventually, I want to get a buzz box for it. Thanks.
Bob
08-26-2005 05:59:18
 Re: Ignition for Engine in reply to TwinCreek, 08-26-2005 04:39:46
Does the engine have a spark plug, or an ignitor?
If it has a spark plug, it would have used a buzz coil.
You CAN use an automotive coil and condenser. However, the ignition timing will be LATE, unless you make some changes there.
Buzz coils spark when the ignition contacts CLOSE, and a Kettering ignition system sparks when the points OPEN. So the timing will be significantly LATER using an automotive coil.
There are quite a few sources for BUZZ COILS, if you search the 'net a bit, and there are usually some on ebay.
Or, nake your own BOZZ COIL. Check out the link below:
Keith A Ault
08-27-2005 18:51:24
 Re: Ignition for Engine in reply to Bob, 08-26-2005 05:59:18
I had a F/M dishpan that I made a bozzcoil for,real simple,battery from breakaway control on trailer,12v coil,Bosch No/NC (avaiable at junk yard,power seats windows) and a knife switch
