Briggs and Stratton 6
erik
08-04-1999 20:57:36
I have a 1954 B&S 6 engine. It is a vertical engine. My question is, how do you remove the camshaft? Does B&S still make parts for this engine?
Thank you
karl brandt
08-04-1999 21:15:09
 Re: Briggs and Stratton 6 in reply to erik, 08-04-1999 20:57:36
B&S still makes some parts for these eninges,like rings,gasket sets,points&condenser,etc.If this is cast iron,you take off the magneto plate & above
the camshaft there is a small plug.Punch this plug
out&the camshaft pin will come out the side.
karl brandt
Everett j Pierce
07-27-2000 19:05:33
 Re: Re: Briggs and Stratton 6 in reply to karl brandt, 08-04-1999 21:15:09
i have an older B&S and i dont know how to tell what horse power it is m, There is no marking on the out side of it. On the crank case it has a screw on oil cap of case iron, and on the botton there is spout with a lid on it , and it is on a spring, The Motor is faily large , and it takes a lot to pull start it , any way i would like to find out so i can some time buy new points for it if it needs them ,, thank you very much
mister33
08-12-1999 10:16:18
need manual briggs and stratton 4hp small motors
