Stationary Engines Discussion Forum
fuel pump
Balfe
09-21-2005 07:08:41
Vf4 dies under load, fuel pump diaphram seems ok to look at,but leaks a little fuel out 4 holes on bottom of pmp. fuel must be getting thru diaphram some how.Are holes there to keep fuel from getting into crankcase?Engine runs fine until load on it. Where can I get a new diaphram?Line is clean and primes ok with lever.Thanks Scott
JT
09-23-2005 17:49:43
 Re: fuel pump in reply to Balfe, 09-21-2005 07:08:41
it would be cheaper to go to an auto parts store and buy an electric pump if this is an electric start model. Fuel pumps for Wisconsins can be quite pricey, low pressure elctric can be had for about 35.00
balfe
09-24-2005 16:54:46
 Re: fuel pump in reply to JT, 09-23-2005 17:49:43
To JT, Can the diaphram be replaced?, or can I get material to make one? This is an old crank start.No electric. Thanks Scott
JT
09-26-2005 14:44:37
 Re: fuel pump in reply to balfe, 09-24-2005 16:54:46
If you can get me the spec off engine or the number stamped on the fuel pump, might be able to answer that question.
Jim
balfe
09-30-2005 15:48:21
 Re: fuel pump in reply to JT, 09-26-2005 14:44:37
To JT, I was talking about the hydraulic pump.It,s made by Webster Electric, Racine Wisconsin. Mod#2HES1-1 or H-7. I don,t know if this company is still in Business? I just want to know how many HP it takes to run it properly? Thanks again Scott
Dale(MO)
09-22-2005 16:13:56
NAPA should have rebuild kits, or complete pumps.
Dale(MO)
zira
09-21-2005 17:55:42
You can get these from a dealer or service place, or they show up on e-bay fairly often.
