Stationary Engines Discussion Forum
ID older model Honda Generator
Gene Davis (Ga.
10-20-2005 18:11:26
Need to ID this one. It is red and white with the gas tank on the top of the roll cage type frame and the tank has a plastic cover that you remove and reach down into it to change the spark plug. It does not have much information on it. Has a flat head Honda engine on it approx the size of the newer Honda GX160 5.5 hp engines. It has the bolt holes on the carburetor not in line. They are staggered over and under the center line of the flange. The only name label I see reads, "Honda E-1500 generator". It is driven with 2 belts from the engine to the generator head. The governor speed handwheel is adjusted manually by watching a volt meter on the panel on top of the generator.It has a manual circut breaker/switch to turn on the a/c current. Would like to know if any body knows what this jewel is. It needs a carburetor cleaning/repair kit job and I would like to know the model of the engine and if there is any where to look for parts for the flat head Honda engine.
