Stationary Engines Discussion Forum
Tune up specs for a Ford Ind 2274E W/Bosch distrib
B Misker
10-22-2005 07:47:03
I need the tune up specs for a Ford Ind 2274E W/Bosch distributor. The engine is installed in a Bobcat 732 skid steer loader.
I need to know the point setting the location of timing marks and the proper amount of initial advance for the distributor. (Asking for a friend. Machine is not where I can examine it.)
Britt
Kent of SW MO
10-22-2005 11:19:40
 Re: Tune up specs for a Ford Ind 2274E W/Bosch dis in reply to B Misker, 10-22-2005 07:47:03
Is this a push rod engine or a over head cammer? The only ford I have worked on in a Bobcat was a little push rod motor which was the same as the push rod motor that was put in early PINTOs. The push rod motor was English made the overhead cammer were German.
Kent
B Misker
10-22-2005 12:51:51
 Re: Tune up specs for a Ford Ind 2274E W/Bosch dis in reply to Kent of SW MO, 10-22-2005 11:19:40
It is a push rod engine.
Thanks,
Britt
