Stationary Engines Discussion Forum
Need Wisconsin TJD and AGND information
Alteran
10-24-2005 13:18:08
I have these on 2 Yazoo mowers and though they run well they are using quite a bit of oil and have what sounds like a faint knock so I guess I'll rebuild them.
A few questions for you. Do these have replaceable rod bearing inserts? Replaceable valve guides? Are there aftermarket parts available or do I have to buy expensive Wisconsin parts? Any source for discounted Wisconsin parts?
Any other wisdom concerning rebuilding them?
Thanks, Al.
doogdoog
10-25-2005 13:53:55
 Re: Need Wisconsin TJD and AGND information in reply to Alteran, 10-24-2005 13:18:08
Aloha, I have bought parts for my engines from the link posted below. The prices are good and would deal with them again (not associated with them).
Link:http://www.midamericapowercenter.com/parts.htm
Mahalo,
doogdoog
zira
10-24-2005 16:31:31
I can second that recommendation, but they are not cheap. You can get aftermarket rings, pistons, etc. but most parts are only available as Wisconsion =$$$. Both of those do have replaceable rod inserts. These are heavy-duty motors like Kohler or Onan & parts cost accordingly.
Ken Hilliard
11-06-2005 16:55:39
 Re: Need Wisconsin TJD and AGND information in reply to zira, 10-24-2005 16:31:31
I was trying to rebuild an early wisc 2 cylinder that had babbitt rod bearings. The rods were blown. Did the early two cylinders only use babbitt bearings for the rod? Or is there a replacement rod with bearing inserts available?
Steve-Maine
10-24-2005 14:51:06
I have been buying parts from www.northeastmachine.com, Nice people to deal with and good prices. Good Luck.
