Stationary Engines Discussion Forum
Engine I.D. Help
doorman
11-03-2005 21:02:58
I just traded for a Case Davis Wheel loader. It has a Wisconsin four cylinder engine on it. I beleive it is a Model W4, but I'm not sure.The i.d. plate ismissing from the fan shroud. It has distributor ignition. I think it was built in the early '70s. It is articulated and has four wheel drive. Thanks in advance for any help in identifying this engine and machine. doorman
Steve-Maine
11-04-2005 14:01:15
 Re: Engine I.D. Help in reply to doorman, 11-03-2005 21:02:58
If you can get me casing number on block, I can tell you what model Wisc.
doorman
11-05-2005 05:09:33
 Re: Engine I.D. Help in reply to Steve-Maine, 11-04-2005 14:01:15
Thanks for the reply. Where is the casting # on the block? doorman
Steve-Maine
11-06-2005 03:10:39
 Re: Engine I.D. Help in reply to doorman, 11-05-2005 05:09:33
Casting number is on lower block either one side or the other, also you can tell date it was made
Gene Davis (Ga.)
11-04-2005 11:00:24
Case-Davis trenchers around here used different series of V4 Wisconsin 4 cylinder engines. They usually are prefixed as something like VF4 or some series ofletters with the V designation. Don't recall seeing any with a W prefix in the model desighnation, . Try posting for the guy on here that uses the nam Zira, he seems to be pretty sharp on these engines.
doorman
11-05-2005 05:07:59
 Re: Engine I.D. Help in reply to Gene Davis (Ga.), 11-04-2005 11:00:24
This is not a trencher. It is an articulated 4-wheel drive front end loader. Later models used a Mitsubishi diesel. The parts guy at Case in Memphis Tn. couldn't tell me exactly, but he said he remembered seeing one years ago. Wisconsin lists a W4-1770,but I don't know if rhere is a connection between the two. Thanks doorman
JT
11-07-2005 06:13:06
 Re: Engine I.D. Help in reply to doorman, 11-05-2005 05:07:59
Don't know if it the correct model for your unit, but a W4-1770 is a newer style 35hp wisconsin v4 engine, so it could very well be W4-1770 engine
Gene Davis (Ga.)
11-04-2005 11:00:18
Gene Davis (Ga.)
11-04-2005 10:59:11
