Stationary Engines Discussion Forum
Wisconsin engine ID needed
Craig A Tull
12-03-2005 12:34:31
I just drug home a Kwik-Mix mixer that has a Wisconsin engine, The data plate is in bad shape
All I can get is two numbers stamped into it 149038 and 93348,I have seen no letters yet.
It looks to be about a 8-10 Hp size with an external mag. Barn fresh, complete and not stuck!!!
Thanks
Craig
Craig A Tull
12-03-2005 18:28:59
 Re: Wisconsin engine ID needed in reply to Craig A Tull, 12-03-2005 12:34:31
Found casting #s on block above the crankshaft(output side) A-24AA .01A, not too sure about the 0. Also It had a round sticker below the data plate and it looks like I can make out 0HP.
Maybe 10HP?
Senlim
12-08-2005 12:40:31
 Re: Wisconsin engine ID needed in reply to Craig A Tull, 12-03-2005 18:28:59
If you are still chasing info in this engine rsvp. I worked for a Wisconsin dealer in the 70"s. From what you have given it could be an S10 or S10D. The D indicates a stelite exhaust valve and seat. The serial number should be 7 digits if made in USA.
John
