Stationary Engines Discussion Forum
Briggs Stratton A or B????
bobcaterdon-BC
12-30-2005 14:09:59
I have this Briggs & Stratton slanted cast iron head engine about 8 - 10 HP and This engine has a 12 volt starter mounted on the side with a V belt around the flywheel with a leaver and switch so it can be started by putting tension on the belt and switching on the starter. Could this be a factory modification or done as a after market upgrade, the brackets and handle look very professionally done???? Sorry havn't fingered out how to post photo?
Kent of SW MO
12-31-2005 08:41:07
 Re: Briggs Stratton A or B???? in reply to bobcaterdon-BC, 12-30-2005 14:09:59
If it is a starter generator, the engine will be later than an A or B. Go to asecc.com and look at the picture posted. This may help you ID this engine.
Kent
