Stationary Engines Discussion Forum
Discussion re: crankcase pressure
Ken52M
01-03-2006 07:38:03
I have a small collection of WI engines.
A VF4 & THD.
I am curious about the crank case pressure dynamics of single cylinder engines as well as twins that are designed w/ both pistons up at the same time (TJD). This will result in large changes in crank case volume during operation. Are there design features to deal w/ this?
KB
Bob
01-03-2006 10:08:35
 Re: Discussion re: crankcase pressure in reply to Ken52M, 01-03-2006 07:38:03
I don't know anything about the Wisconsin system, but others, Kohler for example, have a reed valve the allows air to get out of the crankcase as the piston comes down, and then close to prevent to air from re-entering as the piston moves up, so the crankcase operates at a partial vacuum, eliminating the power losses of pumping the air in and out.
For single cylinder Kohlers, for example, the spec for crankcase depression is 5" to 10" water column at rated RPM's.
Gene Davis (Ga.)
01-06-2006 20:37:03
 Re: Discussion re: crankcase pressure in reply to Bob, 01-03-2006 10:08:35
Negative crankcase presure also helps eleminate oil leaks.
