Stationary Engines Discussion Forum
Maytag compression
Tom/Idaho
01-05-2006 12:23:14
What should the compression be on a 72 D twin. Mine has about 20-25# on both cylinders. That seems a bit low and may contribute to it's hard starting. Also, what Auto lite spark plug would be best?
Thanks, Tom/Idaho
bwegher
01-05-2006 15:54:04
 Re: Maytag compression in reply to Tom/Idaho, 01-05-2006 12:23:14
Compression should be around 60 to start.
Rings often have carbon build-up, and the exhaust port. Make sure the ring grooves are clean. Run-in the pistons after cleaning with kerosene to settle the rings.
Autolite A11LM plugs work for me.
