Looking for a hand held tachometer
chris
03-20-2002 19:17:02
has anyone ever seen a hand held mechanical tach,I was told sawmill folks use one to set mandrel speed.I was wanting one to set diesel governed speed on stuff that does'nt have a proof meter.if anyone knows where to get one I'd appreciate the info
thanks guys, chris
03-22-2002 18:00:16
 Re: looking for a hand held tachometer in reply to chris, 03-20-2002 19:17:02
thanks for all the replies,lots of great info
Lloyd
03-21-2002 15:38:22
I bought one from napa three months ago. They had to order it but was in in a couple of days. Cost about 70.00. Hold tip on center of shaft and reads just like tack, in rpms.
Burrhead
03-21-2002 18:06:48
 Re: Re: looking for a hand held tachometer in reply to Lloyd, 03-21-2002 15:38:22
Harbor freight has one that does real good. You have to put a piece of reflector tape or paint mark on the shaft but it does fine.
Folks around here use them to set irrigation pump engine speed
Joseph F. Cizek II
03-21-2002 14:40:21
I bought a contact/photo tachometer from MSC phone 1-800-645-7270 about 2 years ago to use at work to check shaft and motor rpm . It was about $250 or so with reflective tape and 6 different rubber tips. EXTECH model 00044412 is the one that I bought,other people that I work with bought Brown&Sharpe, Mitutoyo and a couple of off brands that I can't remember what they are. My one coworker has a Brown&Sharpe that is about 9 or 10 years old with out any problems to date. He likes my Extech as well as his Brown&Sharpe. Buy a Brand name one and it will last a long time because the foundry envroment that I work is real hard on tools. Thank you Joseph
Mike D
03-20-2002 22:41:26
Look for an optical tach. You put a white mark or tape on the shaft, point the tach at the shaft and read the RPM, works great. Available at machine shop supply. I think I saw one at Northern Hydraulics or Harbor Freight.
Good luck, Mike
JRN
03-20-2002 20:40:06
Go to McMaster-Carr and enter "Tachometer" in the search window. They have what you are looking for rated to 4000 RPM.
JMS/MN
03-20-2002 19:48:43
I picked one up many years ago at a machine shop sale. I believe it is made by Lufkin. Check some machine tool dealers to see if they might still be available. Mine counts revolutions, and needs to be timed with a watch to get rpm.
Rod (NH)
03-20-2002 19:45:57
third party image
Hi Chris,
Here's what one old-time, low tech one looks like. It is basically a revolution counter that you hold to the end of a rotating shaft and measure the number of revolutions during some standard time period as measured by a stop watch or second hand on a wrist watch. They work real well providing you have access to the end of a shaft or face of a piece of rotating machinery.
I have no idea where you can buy one now-a-days. The one I have is probably well over 50 years old.
Rod
T_Bone
03-20-2002 23:03:56
 Re: Re: looking for a hand held tachometer in reply to Rod (NH), 03-20-2002 19:45:57
Hi Chris,
Stewart Warner also makes them. Used to be avilable at WW Graingers or most Refrigeration supply companys.
Mine has a dial on the end much like reading a pressure gauge with a push reset. The only problem with this type of tach is any grease/oil on the shaft center will cause the rubber tip to slip thus giving a inaccurate reading. No big deal as I just used spray brake or carb cleaner before using the tach.
I also have a electronic Tach sensor that plugs into a DVOM with a type K connector that works well but needs a short piece of reflective tape on the shaft. I use this for setting large HVAC fan rpm as it can be pointed at a floresent light to calibrate the tach at 7000rpm. Floresent lights pulse at 7000/min. Cost was about $20 more than a mechincal tach or $110.
T_Bone
jim
03-21-2002 11:32:23
 Re: Re: Re: looking for a hand held tachometer in reply to T_Bone, 03-20-2002 23:03:56
t- bone who makes that attachment. sounds, neat. i have otc digital tach now, but am always looking at ways to cut down on number of boxes on service truck.
T_Bone
03-22-2002 01:07:58
 Re: Re: Re: Re: looking for a hand held tachometer in reply to jim, 03-21-2002 11:32:23
Hi Jim,
My son borrowed mine so I don't have the paper work to look at in front of me. From Jonstones Supply catalog;
UEI Model DPM2 Part# H24-687 $109.95
accuracy +/- 1.2%
rangeA 100 -1999rpm 1rpm resolution
rangeB 1000-19999rpm 10rpm resolution
you need a 200mVDC range on the DVOM
T_Bone
