3 Phase conversion
Dave
04-01-2002 14:43:47
Does anyone know a way to convert a 3 phase motor (1 HP 220 ) so it will run on single phase,, some say it can be-done without buying a converter? anyone ever do this Dave
frankie
04-07-2002 09:29:54
 Re: 3 Phase conversion in reply to Dave, 04-01-2002 14:43:47
sure can build,but its cheaper to purchase a static phase convertor from KBC tools or MSC, HD 3 HP around 130.00- you can build with capacitors but cant tell you how- understand????? ????? ?
Jim WI
04-02-2002 10:52:54
Go visit one of the online shopping sites of an AC drive manufacturer (Rockwell Automation for example) and see what kind of small AC drives are available. You can get a number of different small drives from various suppliers that can be powered by single-phase 230V power and run your three-phase motor.
By doing this, you'll also get speed control of the machine you're running.
Big Jake
04-02-2002 05:07:20
Link
Mike W
04-01-2002 19:49:51
Hi Dave, do a search on variable frequency drives. You can build your own static converter but will only get about 2/3 of rated hp.
