12v Dwell meter and 6v pos ground on Ford?
Stephen R. Hort
05-16-2002 20:49:38
Can anyone tell me if I can use my regular, cheap-o 12v analog dwell meter to set the dwell on my '59 Ford 861 with 6v positive ground? If so, what is the correct way to hook this up?
thanks,
stephen
Al English
05-17-2002 13:37:18
 Re: 12v Dwell meter and 6v pos ground on Ford? in reply to Stephen R. Horton, 05-16-2002 20:49:38
Hi Stephen,
The answer to your question depends on exactly how your meter is configured. If it is one that requires batteries in order to read dwell, I think there's a better chance it will work. Whether it works or not, you're not going to hurt the meter or the tractor by giving it a try.
Set the points to the specified gap then see what the dwell meter says. It will either say you are at or near the required dwell, in which case it is working, or, the reading will be so far off it is obvious the voltage difference is causing a problem. If the voltage difference is a problem the reading will be off a lot, so don't worry about the meter giving you bogus readings that are just a little off. If the needle bounces against the "0", simply switch the leads to correct for polarity. Good luck...Al English
Stephen R. Horton
05-17-2002 13:48:05
 Re: Re: 12v Dwell meter and 6v pos ground on Ford? in reply to Al English, 05-17-2002 13:37:18
Thanks Al,
I'll give it a shot tommorrow...I was worried about killing my meter.
stephen
Don
05-20-2002 22:05:30
 Re: Re: Re: 12v Dwell meter and 6v pos ground on Ford? in reply to Stephen R. Horton, 05-17-2002 13:48:05
If you got a good set of guages(mine are SNAP ON}and you are careful getting the points on top of the lobe you are dead on....A cheapo dwell meter can be futher off than you guage is....
