14.5 hp Briggs
Po Folks
05-18-2002 20:10:29
Bought a used 14.5 Briggs for my lawnmower and the motor is leaking oil onto the pulley and it is slinging oil all over. Without pulling the motor, can someone give me an idea where the oil may be coming from? The motor was not used for quite a while, so if there is seals to dry up, I guess they did. Thanks,
hlebain
05-18-2002 20:20:40
 Re: 14.5 hp Briggs in reply to Po Folks, 05-18-2002 20:10:29
you might try looking at the seal directly above the the pulley, moer than likly the motor is going to have to come out
Jim K
05-19-2002 04:22:35
 Re: Re: 14.5 hp Briggs in reply to hlebain, 05-18-2002 20:20:40
You want to change the lower crank seal underneath
Also check the crank to see if it's bent, that could be why it's leaking.
Good luck
Jim K
