18 hp Briggs lawn tractor
Bill Sheppard
05-26-2002 06:58:03
Mower ran fine until engine locked up. I since installed new rods, rings etc and now with engine on chassis or on bench with battery connected I cannot get any fire to plugs. I did not change or replace any electrical items even had the solid state coil checked and operation was o.k. Should I be able to get spark to plug even on bench and hooked up to battery? need any info for troubleshooting for the problem. Need it quick my lawn is growing rapidly. Thank you in advance
RACE GENTRY
11-02-2004 12:49:34
 Re: 18 hp Briggs lawn tractor in reply to Bill Sheppard, 05-26-2002 06:58:03
bill what did you come up with ive just had the same problem and even purchased a new coil, and still have the same problem i think it may be in the key switch ?
bill sheppard
05-27-2002 09:10:52
To:
just an idiot and Ray,
I did all you mentioned and now I have the engine on my work bench, hooked up to a battery and still cannot get any spark, However I had the coil checked, they said it was good, but when I came home and checked the black wire that goes from the coil to the post on engine block, it showed a ground even when it was disconnected....should this wire show a ground? thanks to you both for your help so far....need more.
Bill
mac61103
05-28-2002 01:48:07
 Re: Re: 18 hp Briggs lawn tractor in reply to bill sheppard, 05-27-2002 09:10:52
Bill, Just a thought, if the motor locked up while
it was running, could it be the flywheel key??
Tom
just_an_idiot
05-26-2002 19:09:46
you should have spark if you turn it over fast enough. Check gap on coil.check that the wires for on off key is in the on position, check that there is no pinched wires any place.
Ray,IN
05-26-2002 21:16:28
 Re: Re: 18 hp Briggs lawn tractor in reply to just_an_idiot, 05-26-2002 19:09:46
Also check the wiring going to the "safety" switches. One or more of them may have the ignition grounded out.
