2 Cycle Fuel Mix Revisited
PoulanMan
07-06-2002 07:50:54
I'm concerned about the proper mixture of my chainsaw gas/oil. Al English wrote this;
"You might be surprised to know that testing shows richer than necessary oil mixture ratios cause the engine to run hotter".
Is this true? I know if I lean out my saw too much with the high speed mixture screw, it gets hot enough to shut 'er down. The electronic module has to cool off before I can start it again.
Am I missing something somewhere or do I have a module starting to go bad?
Thanks,
PoulanMan
Bret
07-07-2002 06:18:24
 Re: 2 Cycle Fuel Mix Revisited in reply to PoulanMan, 07-06-2002 07:50:54
Back when I was working in a Husqvarna Dealership, the head technical guy for Husky , (Del Leech?), told us at a workshop that too rich a mix caused the big end of the rod bearings to heat up. The tought was that excess oil in the mix would cling to the rod bearing and either burn on or cause the bearing to run slow due to the weight of the oil- I don't remember which it was. When you have a saw running at 13,000 rpm you need just enough oil and no more. We saw a lot of problems with guys who ran Husky's, Stihl's, Pioneers, Mac's and even old Homelites all on the same mix. They'd run about 30-1 and hope for the best. A lot of the Husky's and Stihl's couldn't take that much oil and would have problms.
John in MA
07-07-2002 12:12:02
 Re: Re: 2 Cycle Fuel Mix Revisited in reply to Bret, 07-07-2002 06:18:24
Saw racers who run them at ~14K use around a 16:1 mix. At that speed, it's hard to keep the oil on there. Talk to Ken Dunn if you'd like a real explanation.
Bret
07-07-2002 17:55:35
 Re: Re: Re: 2 Cycle Fuel Mix Revisited in reply to John in MA, 07-07-2002 12:12:02
All I can tell you is what I was told and what I observed. I would imagine a race saw, like a race car, would be totally tricked out and might have to run at 16:1 to hold it together. An everyday work saw would be different. BTW- who is Ken Dunn?
John in MA
07-07-2002 18:07:41
 Re: Re: Re: Re: 2 Cycle Fuel Mix Revisited in reply to Bret, 07-07-2002 17:55:35
A lot of race saws are mostly stock with modifications to compression and port timing. A saw like a Stihl 090 that normally turns at 9K will blow bearings without lots of oil at around 14K.
Ken Dunn's one of the race saw builders. I don't know his email, but he's over on Arboristsite.com.
Ludwig
07-08-2002 14:02:59
 Re: Re: Re: Re: Re: 2 Cycle Fuel Mix Revisited in reply to John in MA, 07-07-2002 18:07:41
Seems like they'd also run better gas too. In a racing snowmobile you might run 104 octane avgas but you'd dammed well better run more oil too or you'll burn bearings.
I think that rarely do things done on race machines wholely apply to the real world.
shoe
07-07-2002 03:21:52
I guess a saw could run alittle hotter with an
excessive oil mixture if it plugged the fire
screen enough to restrict exhaust. I think what
your problem with your saw is the electronic
ignition is going bad. If it was a stihl it would
be on warranty for the life of the saw. Hope you
get it running right.
Al English
07-06-2002 12:32:25
PoulanMan,
Based on how I read your post we are talking about two different subjects.
As you have apparently discovered, a lean air/fuel ratio can cause an engine(especially a 2-cycle) to run hot. A lean air/fuel ratio could, as you described, be caused by an improper carb needle adjustment.
Oil to fuel ratio is another matter. As I indicated, more oil than needed will cause a 2-cycle engine to run hot. Although people who should know have told me this in the past, I didn't truly believe them until I saw data proving it.
So to summarize, too lean an air/fuel ratio is bad....and excessively rich oil/fuel ratio is bad.
If the engine is running on a correct oil/fuel mixture, and it stopping because it is getting tight/seizing, it is most definitely running hot. If it is stopping due to an ignition problem, that's a condition which is often aggravated by heat.
I hope this answers your question/comment...Al English
Don
07-07-2002 09:33:58
 Re: Re: 2 Cycle Fuel Mix Revisited in reply to Al English, 07-06-2002 12:32:25
I have heard you shouldn't use gasohol in a two cycle engine, as the oil will separate from the gas, and ruin the engine. Is this true?
John in MA
07-07-2002 12:13:07
 Re: Re: Re: 2 Cycle Fuel Mix Revisited in reply to Don, 07-07-2002 09:33:58
I hadn't heard that, but the alcohol will sometimes dissolve fuel lines and carb diaphragms. Not a good idea.
ok so why?
07-06-2002 13:49:44
If you read the date please tell us "Why" more oil makes a 2 stroke run hotter and how much hotter, is the temp difference even measueable???
Thanks
Al English
07-06-2002 20:08:24
 Re: Re: Re: 2 Cycle Fuel Mix Revisited in reply to ok so why?, 07-06-2002 13:49:44
I have lots of books, technical papers, notes, etc. We recently sold our house while plans for a new one were still in the initial stages. This means most of my "library" is unfortunately going to remain packed and stored for some time. That being the case I can only tell you what I remember.
I think the temperature(engine metal) differences were about 40 degrees. I don't remember what oil mixture ratios were being compared. If any explanations for this are given, I don't remember what they are.
Two-cycle engines rely heavily on the cooling affect caused by the evaporating fuel charge. I suspect the presence of oil diminishes this cooling affect. It would make sense then that the more oil, the less cooling the engine would receive. Also, the octane rating of gasoline is lowered by the presence of oil. Possibly excessive oil leads to detonation, and the overheating detonation causes.
Sorry I can't provide more specific information...Al English
Glenn(WV)
07-06-2002 21:45:58
 Re: Re: Re: Re: 2 Cycle Fuel Mix Revisited in reply to Al English, 07-06-2002 20:08:24
Al, having a chemistry background, I agree with your opinion that a rich mixture would reduce the evaporative cooling effect and make the engine run hotter. It makes a lot of sense.
I've used two-strokes for years and have never had one fuel-related problem. I had a summer job one year mowing grass at a power plant. The guy, or should I say idiot, in charge told me to mix the Lawn-Boy fuel as 2 1/2 gallons gas to one can of oil "to keep the spark plug from fouling out." If you use a Lawn-Boy, you know that such a mix is too lean. I cleaned the spark plug, the muffler, and the filter, put in a correct mix of gas/oil, and she ran like a champ all summer. I took the lean mix and dumped it into the company truck(which then had a little blue cloud following it for a week, lol).
Get that mix right, and they run great.
John in MA
07-07-2002 12:16:48
 Re: Re: Re: Re: Re: 2 Cycle Fuel Mix Revisited in reply to Glenn(WV), 07-06-2002 21:45:58
I have one of those "bug repellant" Lawn Boys. All the ones made before the late (?) '70s run at 16:1. That's the year they changed the design to use 32:1.
buck
07-06-2002 21:01:21
You say that the presence of oil lowers the octain of the fuel. When considering that the measure of octain is the resistance to combustion then the presence of oil would increase the octain rateing.
Al English
07-06-2002 21:40:46
 Re: Re: Re: Re: Re: 2 Cycle Fuel Mix Revisited in reply to buck, 07-06-2002 21:01:21
Buck,
Kerosene has a higher octane than gasoline, and it seems that oil would too. But consider this, every precaution is taken to keep oil out of the combustion chamber of race engines. That is because they are ideally already on the verge of detonation, and any oil entering the chamber can and will cause detonation and quickly destroy the engine. I don't know the reason oil causes detonation, but there is no disputing that it does. Although oil has a high flash point, apparently its octane rating is low?. Two-cycle engines are not able(due to detonation) to run compression ratios as high as would be possible using the same fuel in a 4-cycle engine. My guess is that the oil/octane situation is at least a good part of the reason why...Al English
Bus Driver
07-07-2002 17:50:44
 Re: Re: Re: Re: Re: Re: 2 Cycle Fuel Mix Revisited in reply to Al English, 07-06-2002 21:40:46
I am usually humbled by the vast knowledge of Al English. I appreciate him helping elevate the rest of us. But on one point I disagree. Kerosene has a much lower octane rating than gasoline. When manufacturers made tractors for "all-fuel", the compression ratio would be quite a bit lower than for the same model for gasoline only. Several manufacturers made tractors both ways for the same model and year.
Al English
07-07-2002 19:49:05
 Re: Re: Re: Re: Re: Re: Re: 2 Cycle Fuel Mix Revisited in reply to Bus Driver, 07-07-2002 17:50:44
Hey Bus Driver,
I'm humbled that you are humbled. And even worse, you are right. Because of the octane difference a diesel engine flat won't run in any fashion with gasoline in the tank. I am very careful to give the best answers I can, and to provide only information that is documentable. But just to add some humanity to the widespread and well known belief that I never make mistakes(you do believe that don't you?), every once in a while I throw something in to see who's paying attention. Seriously, I apologize for the error, and hope no one was misled. Thanks for catching it...Al English
John in MA
07-07-2002 12:19:37
Saw racers use around 16:1 mixes in their hotsaws, although the compression isn't as high as 4 cycle race car engines.
T_Bone
07-06-2002 22:21:07
Hi Al,
Gasoline has about 122000btu/gal
Kerosine has about 128000btu/gal
#2Diesel has about 132000btu/gal
So from that it would explain why a oil/gas mix would have a higher running temperature than straight gas.
T_Bone
Al English
07-07-2002 13:12:07
 Re: Re: Re: Re: Re: Re: Re: 2 Cycle Fuel Mix Revisited in reply to T_Bone, 07-06-2002 22:21:07
Hi T_Bone,
I thought the same thing as you T_Bone, but I have read that much of the oil in the mix doesn't actually burn. However, I don't know how informed the author really was. His contention/evidence was that unburned oil is the source of the smoke and carbon deposits that 2-cycle engines produce. I know smoke consists, at least in part, of unburned particles. So, he may be right. But on the other hand, some of the oil must be burning, what you say makes sense, and could partially or completely explain what's going on...Al English
T_Bone
07-07-2002 23:08:27
 Re: Re: Re: Re: Re: Re: Re: Re: 2 Cycle Fuel Mix Revisited in reply to Al English, 07-07-2002 13:12:07
Hi Al,
The smoke would be burned hydrocarbons, oil turning from a liquid to a vapor state but would also contain saturated oil vapor seen as oil leaking from the exhaust. By adding an excessive amount of oil to the gasoline then the engine temperature would rise as heavy oil has more BTU/gallon than gasoline. By how many degrees I don't know a I never seen any data on cylinder temperatures. You would almost expect pure gasoline to have a higer cylinder tempature as without oil then cylinder scuffing would happen and it would seam friction would add more heat to the cylinder than a over rich gas/oil mix and if that were the case then a lean mixture would run hotter than a over rich mixture. To bad someone has not published an on-line study of cylinder temperatures per oil mix.
I've never seen an offical break down on just how much of an oil mix is burned vs how much is acutally is being used to lube the engine. The EPA would probably have that info but finding it with-in the EPA may be another problem.
T_Bone
Jeff Pack
07-06-2002 08:01:20
Running a 2 stroke too lean will cause high heat...
Burrhead
07-06-2002 18:02:50
 Re: Re: 2 Cycle Fuel Mix Revisited in reply to Jeff Pack, 07-06-2002 08:01:20
yeah and runnin a 4 stroke too lean will make it run too hot too.
Scott Green
07-07-2002 04:18:37
 Re: Re: Re: 2 Cycle Fuel Mix Revisited in reply to Burrhead, 07-06-2002 18:02:50
Yes Burrhead , I've seen many cracked Oliver manifolds. An Oliver machanic told me it was from running too lean. I leave my tractors run just a touch rich. Not enough to smoke. Just enough to leave a slight residue on the inside of the weather cap.
