5W
30W oil Versa's 10W - 30W oil?
Dave F.
09-01-2002 16:58:32
Just, recently aquired an 1999 Ford Explorer, the owners booklet suggested using 5w-30 oil, My 1995 Ford F-150 the book says to use 10w-30 oil the Explorer is an V-6 & the F-150 is an V-8 why the change in oils, also would it be ok to use the 10w-30 I really don't want to stock 2 types of oil. Thanks Dave F.
MARK
09-04-2002 07:39:44
 Re: 5W - 30W oil Versa's 10W - 30W oil? in reply to Dave F., 09-01-2002 16:58:32
dave the 5w30 is recomended but you can certainly use 10w30. if you are in a colder climate you could use 5w30 even in your f150 so you dont have to have two oils to buy.
Mobile 1 5W30
09-03-2002 05:12:17
Have used Mobile-1 5W30 synthetic since 1987 in all cars and pickups. No breakdowns, no sludge, eginines clean, no oil burning, no leaks, no problems. Change at 4000 miles.
Dave F.
09-02-2002 20:34:05
1st,I want to thank everyone for replying to my post. I learned something new, Ludwig, I'll probably will stock the 5w-30w Motorcraft oil (Explorer is under warranty.) No I am not lazy or cheap. Ford used to state in there owners manual the recommend time to change oil was 6,000 miles instend of the 3,000 mile interval, to me this was planned obsoletness, I thought with the thinner oil there would be more wear on critcal parts, Thanks again for everyones reply. Dave F.
Ludwig
09-02-2002 11:15:28
Newer engine, closer tolerances, thats how things have been going for years and will continue to do so.
Closer tolerances, thinnner oil, that doesn't take a genius to figure out.
My '88 GMC called for 5-30 which I ran in the wintertime. In the summer I ran 10-40 which leaked alot slower. 150,000 miles and it ran great.
My wife's cheapo '91 Ford Tempo only ever gets 5-30, 140,000 miles and it still runs like a champ.
My '96 Dakota calls for 10-30, but the dopes at quickielube like to slip in 5-30 sometimes. When they do I go back for a free oil change in 1000 miles because it leaks the 5-30 so bad I'll be down a quart and then I think the check the slip.
It doesn't leak a drop with 10-30. This happened 3 or 4 times when I first bought the truck, I didn't really complain because with the free (I love free) 1000mile oil changes I figured I was giving the engine a good cleaning.
Thats the other reason I recommend our local quickie lube place, they're real eager to fix any screwup. I tell 'em what happened and they fix it, no worries.
In your case you don't say how many miles on the Explorer or if it leaks oil. If it doesn't leak much I'd use the 5-30. How much of a hassle are we really talking about here?
I have a friend who ran 10-40 in his wife's vw golf in the summer and one winter forgot to change it back, just kept with the 10-40. We had a cold snap and a couple days in she came up with a bad runner.
After putting in a new camshaft he never made that mistake again. Apparently this was a big problem with the VW Golf in cold climates.
Remember, no matter how bright you figure you are, the guy who made that oil recommendation did it for a reason. If you can come up with a real good reason to switch, like my GMC's summer oil, then its probably ok. If you're just lazy you're asking for trouble.
Sal
09-02-2002 05:12:31
Ford is now specifying 5-20 oil, not 5-30 on the new Rangers, Expeditions and others.
When I got my Ranger last year it was tough finding 5-20 oil at first, now it's everywhere.
I don't see how you can go wrong using what is specified by the owners manual.
I Stock 5-20, 5-30, 10-30, 30 in my shop, a couple of cases of each. It never goes bad on me and I have the right type on hand for each vehicle.
Sal
Sal
09-02-2002 05:09:46
Sal
chris
09-01-2002 20:04:40
Dave, I have ran 10w30 in both a 91 pontiac with a 2.0 liter ohc 4cyl. that has 160,000 miles and a 95 Oldsmobile with a 3.1 liter V6 that just turned over a 100,000 miles both are running strong. I use Kendall Oil if you were wondering. All my mechanic buddies frown at 5w30. If anything use the 5w30 for the winter. chris in nebraska
Don LC
09-01-2002 19:00:35
The motor companys used 5w oil as a way to reach the fleet gasmillage goals set by the goverment....I put 97,000 miles on a Ford Ariostar Van using 10w-30w oil never had a problem.....I have 16,000 on a Windstar,doing fine so far ----both serviced by the dealer.....
Glenn(WV)
09-01-2002 18:52:06
If your Explorer is under any sort of warranty, use the 5W-30; if you don't, the dealer may refuse to repair engine problems under warranty. If your Explorer is out of warranty, use whatever you want. Personally, I'd use the 5W-30 anyway.
Mac
09-01-2002 17:25:13
Dave I dont think you have a problem using the 10/30 instead of 5/30. I do know GM states 5/30 on their cars but dealers usually put in the 10/30
at oil changes. The 5/30 will give quicker lubrication in cold weather. I think this is the theory on the lighter oil. I would not be afraid to use the 10/30.
stihltech
09-01-2002 18:57:17
 Re: Re: 5W - 30W oil Versa's 10W - 30W oil? in reply to Mac, 09-01-2002 17:25:13
5w30 has been the recommended oil for at least 12 years. Gm dealers were the first to put it in, I was there then. The biggest bearing wear occurs at startup. The faster the oil reaches the bearings, the less wear. 5w30 will reach the bearings around 30% faster than 10w30. This is part of the reason motors are lasting longer. Use the recommended oil.
