57 chev 6cyl how to convert to 12volt Alt
BUCK
10-21-2002 20:39:26
How do I wire the 1 wire delco 12volt Alt. Should I use a chrysler cut out????
Jon Hagen
10-21-2002 20:52:30
 Re: 57 chev 6cyl how to convert to 12volt Alt in reply to BUCK, 10-21-2002 20:39:26
All you need to do to connect a 1 wire Delco alternator to your generator system wiring harness is to extend the wire that was connected to the generator regulators BAT terminal and connect it to the BAT terminal on the alternator rear.
No other regulator or cutout is necessary.
