4x6 Bandsaw question
Morty _alberta
12-09-2002 14:49:01
I recently got one of these beasts and went to change the oil in the gearbox before use, I was told to use 140 wt - the local NAPA and others don't have this, Can I use 80/90 gear lube or is it a problem with the worm gear ??
Scott V
12-09-2002 15:52:59
 Re: 4x6 Bandsaw question in reply to Morty _alberta, 12-09-2002 14:49:01
Morty,try a local truck supply house.I found this brand at a local napa store.
(Sta-Lube- multi purpose Hypoid 140- gear oil- api/gl-4- part no. SL24238- 1 gal size)I have seen it in quarts.I went though the same drill for my horizontal mill.Stick with the 140 weight.
