3 years of auctions and now to built a working snow plow
Nellie
12-15-2002 04:24:52
First off this is an off road project only, just for my own driveway and barnyard. The only safety consideration is that I do not run over the dog. I have accumulated over three years of auctions a full size Ford Bronco, Fisher vehicle mount frame, old belt driven hydraulic pump and controls and a HD plow blade. Of coarse nothing fits together and requires modification but I only spent $200 on all the items mentioned. I have a couple of questions. Do I need a separate belt for the Fisher pump or can I drive both the plow pump and Bronco PS pump off the same v-belt? 2nd any good sites that specialize this type of project. Thanks
Nellie
12-18-2002 13:49:03
 Re: 3 years of auctions and now to built a working snow plow in reply to Nellie, 12-15-2002 04:24:52
Thanks Kevin and AL2. Things are going well on the project. I took the air pump off the Bronco. I'm able to use that freed up pully space and it even turned the hydraulic pump in the right dirction. I checked out those plow sites and got some good Ideas on how to best modify the frame that will be completed 12/20. Thanks again.
Nellie
Kevin
12-15-2002 18:16:21
My hydralic pump is installed where the air conditioner compressor setup would be. It gets its own bracket and belt. The power steering and pump would put too much drag on one belt, but a double pulley system would probably work if thats less trouble to install.
AL 2
12-15-2002 12:03:35
Here's another site. I forgot it on the post above. >Link
Al>Link
AL 2
12-15-2002 07:31:03
Check out>Link
Al
