3 phase vs. single phase
Dick
12-30-2002 12:25:46
All other things being equal will 1 1/2 HP motors develop the same power under either phase.
Thanks
Dick
Evan350
12-31-2002 11:38:21
 Re: 3 phase vs. single phase in reply to Dick, 12-30-2002 12:25:46
If you upgrade to 3ph service, you'll probably be subject to a demand charge. Look into Time Of Use (TOU) metering, which will give you reduced rates at off-peak times.
MarkB
12-31-2002 04:29:33
The primary advantage of three phase is reduced vibration. It's not a big deal on smaller motors, but that's why you don't see any big single phase motors.
As other posters have mentioned, three phase doesn't require a separate starting circuit.
rhudson
12-30-2002 19:12:59
3 phase will develope about 150% more starting torque than an equal horsepower single phase. the main advantage of three ph is easy starting and easy reversing. takes an extra winding to get a single phase motor started. its a weak "link". as others have said, running power and running torque about the same with either power.
Greg S
12-30-2002 13:13:55
Yes. Power is power is power. 1 1/2 HP rated motors will use the same amount of electricity (KW) irregardless of whether it is single phase or three phase. The only real advantage of multi phase power is that the amperage draw on a single conductor is less with multi phase power vs. single phase power and the conductors can be smaller in size (less costly). The disadvantage of three phase power for the average person is the demand charge that usually must be paid on three phase service.
Wardner
12-30-2002 19:04:54
 Re: Re: 3 phase vs. single phase in reply to Greg S, 12-30-2002 13:13:55
I have 200 amps of 208v three phase and I do not pay demand charges. The power company put it in thirty years ago and did not charge me for the transformer either. I think they would at this time. The only problem I have is a fuse on their pole that blows every couple of years. Those interested in commercial power should check with local power company for rates and types of service. My service gives me the flexibility to purchase what ever I want in the way of machine tools and motors. And I am not limited to 10hp which is the max on 220v single phase.
Wayne
12-30-2002 23:47:11
 Re: Re: Re: 3 phase vs. single phase in reply to Wardner, 12-30-2002 19:04:54
Your right about the power company charging for 3 phase service nowdays, at least in NC. We checked several years ago about having a service pulled into our shop, and the price we got back from them was in the neighborhood of $8000. Thing is that's for a pull of maybe 1 1/2 blocks from the lines feeding the VFD up the road which has the closest 3ph service. We had used a small static converter for a while, but wanted to step up the size of our compressor, but a static type will not handle the starting loads of a compressor. So we chose instead a 20 HP, running load rated, Roto-phase converter. We had to size based on it's capability to handle a 7.5Hp compressor under the starting load because a compressor has a long, high amp draw on startup (many single phase motors you'll see are rated as "compressor duty" for this very reason, that's why most are capacitor start, to make up for their inherent weakness, as one of the other posts stated). I believe it's max single motor starting capability is 10 Hp, but with a converter this large you also have a minumum single load of about 3HP for the converter to put out full voltage on the manufactured leg. So we just set the compressor up for continuous run and it acts as an idler for the smaller motors connected to the circuit. We've been running our machine shop this way for the past 4 years with a 5HP lathe, 1 1/2Hp drill press, 1/2 Hp tool grinder, 2HP Bridgport mill, a 1HP hydraulic power unit powering an old lathe we've converted to a buildup machine for redoing worn shafts, etc, plus various other things we've had plugged into it over the years. Through it all we've never had any problems. I wired the system in using a 3 pole contactor interlocked with the motor starter for the converter that way it prevents single phasing any of the equipment (ie- there is NO power to the equipment at all if the converter isn't running). The only problem is running an industrial 3-phase welder on a converter is another story. Acording the the folks at Roto-phase, it can be done, but then you still get back into the whole minimum and maximum amp draw thing. If you get a machine with a large draw at high output, then you need a large converter to handle it, but when your welding at a lower output, you would then have to have some sort of idler motor/load to keep full output on the manufactured leg. Well good luck guys. Sorry for such a long post but this is just my 2 cents based on personal experience, hope it helps some of you out.
ed b
12-30-2002 18:32:10
if it is less amps would it not mean that it is cheaper to run if you all ready have a 3 phase service
G Taylor
01-02-2003 10:06:37
 Re: Re: Re: 3 phase vs. single phase in reply to ed b, 12-30-2002 18:32:10
Power is volts x amps. To the same amount of work if the amps are halved the voltage must be doubled. Gets more complicated if power factor and three phase vectors are incluided. I could never get it through my Grandfather's head that he wasn't saving 1/2 of his electrical hot water heater energy costs by connecting it to 120V instead of 240V.
matthew
12-30-2002 20:00:50
Technically the answer to your question is "usually". However, there are several things we must know to get a handle on the total actual cost that is not worth enough pennies either way to run our 50 hp or less home shops. If you have a 50,000 hp manufacturing plant, that is another story.
To your point though, we don't purchase current (amps) we purchase kilowatt-hours (KWH) from our power supplier. For our purposes, it requires basically the same amount of metered kilo-watt hours to run a loaded 1 hp motor an hour whether it is 120, 240, or 208-3phase even though the line current is different in each case.
