3 speed motor
Bill Z
01-23-2003 17:50:21
Our church has unit heater with 3 speed motor attached to squirrel cage fan. It also has a three position switch. We just got a new motor and I got it to work, but only with two speeds. Where can I find a wiring diagram to hook it up?
G Taylor
01-24-2003 18:19:03
 Re: 3 speed motor in reply to Bill Z, 01-23-2003 17:50:21
Some motors energize both sets of run windings to get the 3rd and slowest speed.
Kevin C.
01-24-2003 13:39:08
How many wires does your replacement motor have and what are their colors? you may or may not have a 3 speed motr. What is the brand of the replacement motor? Most motor shops sell FASCO brand replacement motors. You can go to www.fasco.com/pdf3/page36-38.pdf for hook-up diagrams for FASCO 3-speed motors.
Also what brand is your HVAC device? Carrier and Coleman have good sites that explain 3 speed hook ups.
Bill Z
01-24-2003 19:56:49
 Re: Re: 3 speed motor in reply to Kevin C., 01-24-2003 13:39:08
FASCO had exactly what I needed. Thank you very much. It is amazing the help you can get here. Bill
Mac
01-24-2003 12:54:32
I stand to be corrected but seems a 3sp will have 4 wires, 6 wires if it is capicitor start.
Ben in KY
01-24-2003 12:40:25
Are you sure you got a 3 speed replacement motor. It could be just 2 speeds. slowpokes wiring recommendation is about all I can say on that angle too.
Slowpoke
01-23-2003 20:42:19
There usually is a diagram somewhere on the cabinet cover. Or one should come with the new motor, maybe on the terminal cover, if not on a seperate paper.
Bill Z
01-24-2003 12:48:20
 Re: Re: 3 speed motor in reply to Slowpoke, 01-23-2003 20:42:19
I can't find anything usuable.
