2 stage air compressor
Steve Sheppard
01-30-2003 17:05:48
I have an older Sanborn air compressor. 10 yrs apprx. Last night when it started running after sanding for 30 min, I could hear the motor really lugging down. I went to check and the motor had almost completely stopped but I could hear it wanting to keep running. I removed pulley belts and motor ran fine. I then tried spinning pulley on compressor and it felt like it had pressure against it, but I could move it. I manually pressed bleed off valve, but this didn't seem to make any difference. Any ideas of what to do? There are no service shops in my town.
Vijendran
05-06-2005 09:20:54
 Re: 2 stage air compressor in reply to Steve Sheppard, 01-30-2003 17:05:48
I want to buy the compresser.....
want more information.... plz send me info about single stage and 2 stage compresser.
Ben
01-30-2003 17:22:06
Steve:
Sounds like your check valve is no good. The tank pressure is building up in the head and the motor can't handle the pressure of the tank. To see if its the check valve( its usually located in the tank just at the end of the main in feed line to the tank), let all pressure out of tank re-connect everything and if same sympotons appear at around 50-60#'s thats most likely your problem.
Steve Sheppard
02-01-2003 08:51:15
 Re: Re: 2 stage air compressor in reply to Ben, 01-30-2003 17:22:06
Thanks guy's. It was the check valve. Put new one in and runs as good as new again. I have always used the oil from Ingersol Rand for compressor.Is it neccessary or will regular motor oil work. Again thanks for your help:}
cannonball6
02-02-2003 08:58:19
 Re: Re: Re: 2 stage air compressor in reply to Steve Sheppard, 02-01-2003 08:51:15
yes 10 40 will work but i run compressor oil in my, i have a fresh air supply hood and i use the compressor oil that is for them..have nice day may god bless the familes of the shuttle and all
Steve Sheppard
01-30-2003 20:11:08
Well, I pulled the check valve out, how do I determine if it is bad?
Philip
01-31-2003 09:11:38
 Re: Re: Re: 2 stage air compressor in reply to Steve Sheppard, 01-30-2003 20:11:08
Steve, now that you have the check valve out, disconnect all air lines on the pump. Is the flywheel still hard to turn over? A bad check valve would bleed a full tank down over a couple of days. One way to check. Put check valve back in tank. Do not connect pump outlet line to valve. Pressurize tank with a second compressor. See how long tank holds air. See if there is air escaping from the inlet of the check valve. Philip.
Don LC
01-31-2003 04:15:53
Pressure guage on the tank should tell you smething....take the valve to a big dealer,he should be able to check it....How about the oil int he pump.....I have run 10w - 40 in mine now for about 25 years..... ..I have the tank pressure set at 140#...working pressure at 100#
