110V Welder
Southern Exteri
03-01-2003 08:53:38
Are there any good 110V welders out there? I don't need to build a horse trailer, I just want to fix something every now and then with out having to get a welder here or take something to a welding shop.
mike
01-04-2004 12:52:20
 Re: 110V Welder in reply to Southern Exteriors, 03-01-2003 08:53:38
110v welder due a good job but use flux core over mig because of the polarity it will draw the weld in deeper /stonger weld. allso arc stick welder is even better. note higher amprage is better 125 min. mig is just a pretty weld where as you clean flux with wire brush and a chiping hammer in some cases. look for something that will weld 1/4 inch. century use to make a gs155
Greg Miller
03-13-2003 09:33:43
i use a small 120V wire feed welder made by HOBART. it has the regulator kit for use as a mig welder also. i have found that it works pretty good as long as you are not trying to weld anything to thick for the machine to handle. in general it works well. however, i would suggest that you would want to use the regulator kit with a tank of argon and weld as a mig machine. i dont have the kit installed or a tank of gas so therefore i get a little more splatter than some people could accept.
IowayBoy
03-02-2003 07:06:10
I've no 220 outlet.Was given an old Shamacher 110 welder.Have used to spot weld sickle sections for temp fix,welded b slats back on bale ring,etc.Limited but handy.Don't know best kind to get,tho.
John in Md.
03-02-2003 03:40:26
If you already know how to weld,the 110's are fine.But if you are trying to learn,then get the bigger 220 unit they are more forgiving.The 110's have a use,for light stuff,but a 220 has a much wider range.
DumOleBob
03-02-2003 08:08:08
 Re: Re: 110V Welder in reply to John in Md. , 03-02-2003 03:40:26
I completely agree! I've got a Hobart 110v. It's great for small, non-critical stuff under 1/4". Also portable so you can take it to Grandma's house. Love it, but mostly go with my bigger Millermatic since it is "more forgiving".
To me it's like HORSEPOWER - you'll alway wish for a little more.
hay
03-02-2003 02:56:15
i had the same idea. bought a small cheap 110 volt welder and found out very quickly it would not do much. i had to bite the bullet and then buy a big 220 volt miller ac and what a difference that made. i can weld anything on my farm machinery and even build a few projects ( like a trailer) and have power to spare. you will always find things to weld so it is better to get a big strong one right off. it will sure save you money in the long term.
