240v buzz box welder
ken
04-26-2003 12:28:02
hi i was wondering if i can use my 240v 40 amp welder on my dryer plug?and or my 5000w generator....could this be possible... iwould love somei mput...in detail
Elwyn Eaton
07-01-2005 14:30:45
 Re: 240v buzz box welder in reply to ken, 04-26-2003 12:28:02
what size amps breaker should i use with a 240v buzz box welder.
John Baker
09-28-2004 06:11:26
I'm interested in a way to weld seams on a 16 gauge stainless box without buying an expensive robotic setup. Any ideas?
ray
04-29-2003 08:24:41
Yes and NO. Low heat settings Yes High No.
Last night I used my Thunderbolt XL @100amps 3/32 -6011 no problem. (On a Generac 5000 watt generator)
Referencing>Link
AC Voltage @100amps ~55volts AC
Watts = 55*100 = 5500watts House draw = 5500/240 volts ~ 23 amps These are probably very liberal questimates....
KEG
04-28-2003 21:11:32
FWIW I just bought a 4000 W Generac and hooked up my 225A Lincoln buzz box to see if it would work. Did 75A, then 100, then 120A with no problem. It would not run my 6hp compressor, though. But I will probably return it for the 5500W unit. Even thought it ran the welder, 4000W seems a bit too small for the long term.
KEG
Gene Davis
04-27-2003 19:22:27
I have a 225 AC/DC lincoln welder, and it pulls almost the full load on my 8KW generator. Gene
MPK
04-26-2003 17:50:15
You may be able to weld with the gen. if you keep the heat setting around 100 amp or less.
hjp
04-26-2003 15:23:41
My lincoln ac-225 uses a 50 amp beaker/replaced the dryer 40 amp . I made a lead/adapter cord. dryer (male) plug to a the lincoln supplied female electric box using 50 ft of 2/0 wire and works well.
5000 watt generator is nowhere near enough juice to run a 240v/ac-225 amp welder !!!!!
Robert in W. Mi
05-01-2003 14:59:18
 Re: Re: 240v buzz box welder in reply to hjp, 04-26-2003 15:23:41
Did i read this right? Did you upgrade the wire in the wall to your dryer to a size big enough to carry a 50amp breaker (you said it had a 40) with out being overloaded????? ? If not, it's a good way to start a house fire!!!! Robert
