2-7/8 Column for Drill Press
Treegunman
05-11-2003 18:34:59
Does anybody out there have a drill press with a 2-7/8" column? I broke the work table bracket on my Duracraft 500 and I am running into dead ends trying to find parts for it. Thanks in advance.
Seals
10-28-2004 13:04:39
 Re: 2-7/8 Column for Drill Press in reply to Treegunman, 05-11-2003 18:34:59
I have a Duracraft drill press for sale. Would you be interested in a second one for parts? Maybe Robert Stott could use some of the parts.
Fred OH
05-15-2003 07:59:41
You can braze the broken casting as it's cast iron...so...you shouldn't need any new parts for it...just someone to weld it. (Probably a weld shop) Also if you're going to center punch metal on the table of these drill presses...you shouldn't use over a 16 ounce hammer and not do it at all when the shop is cold. Cast breaks easier when theres frost on it. Those drill presses are extremely top heavy and will fall over if you breath on them...they should be lagged to the deck...or bolt on a wide piece of plate steel on the bottom to keep it from happening. Just my observations...what happened to yours? Also, if you weld it...don't forget to add a shim if it is broken through the clamp on the column so it will clamp tight to the column. L8R....Fred OH
JMS/MN
05-12-2003 22:50:41
Is it really 2 7/8? Local blacksmith just dropped his Taiwan special and broke the column- found out it was metric..... .bought a Craftsman.
Robert Stott
08-18-2003 19:06:19
 Re: Re: 2-7/8 Column for Drill Press in reply to JMS/MN, 05-12-2003 22:50:41
I'm also find hard time on my 500 durcraft drill press looking for a 5 speed spindile pulley and large nut for top
evielboweviel
05-13-2003 06:21:23
what makes you think craftsman is still made in the USA?? look at the tag on it
JMS/MN
05-17-2003 12:12:28
 Re: Re: Re: 2-7/8 Column for Drill Press in reply to evielboweviel, 05-13-2003 06:21:23
Didn't say it was made in the USA, but parts are only a phone call away, and two stores are within 25 miles.
JoeK..Maybe??
05-11-2003 19:41:19
Found letter on woodworking forum(1999)which adv Duracraft was bought by Honeywell?
"Duracraft was sold to honeywell for $283 mil. i have a drill press by them. I am looking at the web for them.found phone number 1-800-290-8495 try it" ----- ----- ----- ----- ----- -
Dunno if this will help or not,Good Luck
