50 hz generator
ray
06-25-2003 07:00:07
Is it a bad move to run welders (mig, stick) (220AC) or power tools off of a 50hz generator? Will they just run slower but have the same torque for that rpm?
Thanks
george md
06-25-2003 09:15:50
 Re: 50 hz generator in reply to ray, 06-25-2003 07:00:07
Ray ,
Most 60 cycle equipment running on 50 cy will draw more current and run hot . many generators can be adjusted up to 60 cy , if it is a
two pole machine it will be running at 3000 rpm, set rpm to 3600 for 60 cy. If it is a 4 pole machine it will be running 1500 rpm , set to 1800 for 60 cycle.
george
