1945 H FARMALL • NEED HELP
CARL PATTONQ
07-01-2003 19:21:52
CAN ANYONE TELL ME HOW TO GET RADIATOR OFF.
STERRING ROD GOES THRU TOP TANK OF RADIATOR. I NEED TO KNOW HOW TO GET RADIATOR OFF ROD.
chads
07-02-2003 13:46:34
 Re: 1945 H FARMALL • NEED HELP in reply to CARL PATTONQ, 07-01-2003 19:21:52
remove the grille, remove drain plug, undo top and bottom hoses, there is two types of top support brackets, one bolts directly to the thermostat housing with one bolt,or it has a rod that goes back to the gastank/steering column. remove. remove fan shroud 4 bolts, then there is a large threaded plug that is on the front end remove the cap, and undo the steering linkage at the gas tank. the shaft left over that goes through the radiator should screw out of the worm gear in the front end. good luck
